Does yours burn oil
Thumper
Does yours burn oil
#1 Post by Thumper » Thu Nov 13, 2008 10:27 pm
Got talking to a aprilia rider in the pub worried sick about his engine burning oil :smt012 he spent a small fortune at his dealer with no result. In conversation he told me the problem started after he had a new clutch fitted.!!
This set alarm bells ringing for me as i remembered reading about a similar problem anyhow cutting a long story short we had the cover off his clutch and yes a small nick in the rubber diaphragm was found. some carefully applied brake cleaner and a puncture outfit patch provided a repair and guess what no more burning oil :smt003
Always expect the unexpected
#2 Post by D-Rider » Thu Nov 13, 2008 11:19 pm
Yeah - that is a good point to remember - cheers
(BTW, I'll copy this to the Aprilia Technical section as it affects all of the V60s)
sl1000_dk
#3 Post by sl1000_dk » Tue Nov 18, 2008 9:45 pm
My falco have started to use oil, smell, and smoke.
I read this thread yesterday and decided to check out the clutch today and, yes the diaphragm had a small hole(see pic 6). how much oil are there supposed to be between the clutchcover and the diaphragm ?
There were about 10-15 cl oil in mine( see pic. 4)
1
2
3
4
5
6
Falco9
#4 Post by Falco9 » Tue Nov 18, 2008 11:07 pm
I'm pretty certain that when I changed my clutch plates to Barnett ones the space between the casing and the diaphragm was completely dry on my Falco.
I dont even remember seeing that much oil anywhere but I had put the bike on the stand to prevent me from even having to drain the oil
Hope I'm wrong in this case for once !
F9 :smt006
sl1000_dk
#5 Post by sl1000_dk » Wed Nov 19, 2008 8:51 pm
Thanks for the the reply falco 9, but why do you hope that your wrong.
I´m happy if i change the diaphragm and it will solve my problem. I was ready to take the engine out, and change the pistons ring.
regards
Martin Poll
Falco9
#6 Post by Falco9 » Wed Nov 19, 2008 10:01 pm
sl1000_dk wrote:Thanks for the the reply falco 9, but why do you hope that your wrong.
regards
Martin Poll
Hi Martin,
I cannot understand why I said that either....I was tired I guess
Hope this fixes you're problem though!
F9 :smt006
#7 Post by HowardQ » Wed Nov 19, 2008 10:48 pm
Yeh, not having to rebuild an engine, just replace a diaphragm seems pretty good news to me too!
Hope it has cured it.
Thumper
#8 Post by Thumper » Sun Mar 29, 2009 4:00 pm
Another reported cause of clutch slipping problems can often be a plastic non return valve that lives some ware up above the clutch and connected to a tube up to the air box but I never found mine when I wanted to check it.. :smt020
